  3. Why are items not importing in the correct position from...
  • Views 9927
Why are items not importing in the correct position from dxf to cadence
tmd63
tmd63 over 4 years ago
I have a dxf file which has a number of copper pline arcs.
When i import them, the arcs move position?? Why does this happen?
  • DavidJHutchins
    0 DavidJHutchins over 4 years ago
    Can you share the dxf file so we can look into the issue?
  • steve
    0 steve over 4 years ago
    Check the co-ordinates of the DXF v the PCB layout. the origin (0,0) nneds to match otherwise you could see what you are seeing. I'd also check the units and accuracy (decimal places) to make sure they match.
