  3. Loading of Technology File by starting of OrAD PCB desi...
  • State Suggested Answer
  • Answers 1
  • Subscribers 171
  • Views 10792
Loading of Technology File by starting of OrAD PCB designer
JuriV
JuriV over 4 years ago
Hello everybody,
to load my technology file I am using
"set techpath = D:/.../TechFiles".
After start of Orcad PCB designer the parameters stored in the Technology Files are not appears in the Constraint Manager.
I should to import my Technology File in the Constraint Manager again to see any changes.
Everybody knows why t can not be loaded automaticaly by starting of the PCB designer?
Best regards
  • excellon1
    0 excellon1 over 4 years ago
    Hi Juriv.
    Your "set techpath = D:/.../TechFiles". only tells Allegro where to look for a technology file but it does not mean that the technology file will be auto loaded when you launch allegro or create a new blank PCB board file.
    To use your tech file you have to load it manually. Go to file import > Tech file, select the file you want and click import. This will import your tech file. You can also import the technology file in the Constraint Manager too. Open the CM and choose file import technology file.
    FYI the technology file only contains the physical stackup of your board.
    Hope this helps you out ..
  • agelababypo
    0 agelababypo over 4 years ago
    The problem only occurs once updated to 17.4, if this happens to give any insight to what might be the issue.  paper io
  • juliejohn
    0 juliejohn over 4 years ago in reply to agelababypo
    Let me know if the problem solved as I have not updated it yet. news busters
