  3. Can manufacturing constraints (PKG-PKG spacing) be reused...
  • State Verified Answer
  • Views 9616
Can manufacturing constraints (PKG-PKG spacing) be reused in OrCAD 17.4 Professional?
JITHINDEV
JITHINDEV over 4 years ago
whether the manufacturing constraint (PKG-PKG spacing) in OrCAD 17.4 PCB editor can be reused ?
Thanks in advance!
Cheers
Jithindev MK
  • oldmouldy
    oldmouldy over 4 years ago +1 verified
    Yes, In Constraint Manager, File>Export>Constraints and select the Constraints that you want to re-use, just Design for Assembly in this case. Then File>Import>Constraints from Constraint Manager in the…
  • oldmouldy
    +1 oldmouldy over 4 years ago
    Yes, In Constraint Manager, File>Export>Constraints and select the Constraints that you want to re-use, just Design for Assembly in this case. Then File>Import>Constraints from Constraint Manager in the "target" board.
