  3. Flex PCB edge connector
  • Views 10211
PurdueMark
PurdueMark over 4 years ago
Looking for a tutorial on how to create an edge connector for a flex PCB to plug into a standard ZIF connector.   I've searched on-line quite a bit and have found little info
MSC   10/4/22
  • steve
    0 steve over 4 years ago
    This may help How to Define a Double Sided Surface Mount Component (parallel-systems.co.uk)
  • PurdueMark
    0 PurdueMark over 4 years ago in reply to steve
    Thanks for the info,  but my application is single-sided.   I'm confused with how I can use a symbol to define the edge of the PCB.    The ZIF connector (that the board plugs into) requires a certain cutout to fit and hold it in the connector.   So I started looking for a board template with that cutout,  but it also needs to be a symbol for the net information.   Surprised I couldn't find anything even for a standard rigid PCB edge connector.
