  3. Is there a way to backup and restore your preferences?
  • State Verified Answer
  • Views 12212
asdfafasfaf
asdfafasfaf over 4 years ago
Say I need to reinstall OrCAD PCB Professional, or I want to set it up on a second machine. Is there any way to back up all my settings so that I don't have to manually reconfigure everything on my new machine? Is it enough to save the env file? Is that even safe? For exmaple if the username in Windows was changed?
  • DavidJHutchins
    DavidJHutchins over 4 years ago +1 verified
    I think that archiving the contents of the pcbenv folder should keep all the allegro related settings, not sure about the OrCAD frontend tools If the user name changes the contents of the pcbenv goes…
  • DavidJHutchins
    DavidJHutchins over 4 years ago in reply to asdfafasfaf +1 verified
    Look at the setting of your Windows 'HOME' variable Go to Control Panel - System - Advanced System Settings - Environment Variables and look for the HOME variable. This is where the pcbenv folder is…
  • DavidJHutchins
    +1 DavidJHutchins over 4 years ago
    If the user name changes the contents of the pcbenv goes into the c:\Users\<username>\pcbenv folder
  • asdfafasfaf
    0 asdfafasfaf over 4 years ago in reply to DavidJHutchins
    My pcbenv folder is completely empty. I'm not sure if it is could be because I have a space in my user account name.
  • DavidJHutchins
    +1 DavidJHutchins over 4 years ago in reply to asdfafasfaf
    This is where the pcbenv folder is located
  • asdfafasfaf
    It turns out that the HOME variable wasn't defined at all. So now I've got it all figured out. Thanks!
  • Schulz Jordan
    0 Schulz Jordan over 4 years ago in reply to asdfafasfaf
    asdfafasfaf one option is to reuse the pcbenv. Second option you can export - parameters & Import them on second machine
