  3. stacking micro via over buried via
  • State Verified Answer
  • Subscribers 167
  • Views 13834
JITHINDEV
JITHINDEV over 4 years ago
Anyone please help me on this.
I have given micro via buried via stacking on my board.
whether micro via stacking over buried via will cause any reliability issue? is it not recommended to do this this method ?
Regards
Jithindev MK
  • RFinley
    RFinley over 4 years ago +3 verified
    Coincident over mechanical drills will be a yield problem if you don't pay for filled/planarized/plated core vias. Extra processing steps to minimize risk of opens. Talk to your fabricator. Even If you…
  • masamasa
    masamasa over 4 years ago +3 verified
    stacked vias may cause reliability issues such as cracks. so determining the diameter of vias and catch pads is a key to pass the reliability tests.
  • masamasa
    0 masamasa over 4 years ago in reply to JITHINDEV
    stacking a via over a via is prone to cause issues such as cracks on the bottom side of the via. to prevent this issue, u may need to create several test vihecle designs with various via and catch pad sizes to see which is the best without having any issues on reliability tests. the designs can be simulated as a mechanical model or actually manufacured and gone thru the reliability tests.
