  3. stacking micro via over buried via
  • State Verified Answer
  • Subscribers 167
  • Views 13833
JITHINDEV
JITHINDEV over 4 years ago
Anyone please help me on this.
I have given micro via buried via stacking on my board.
whether micro via stacking over buried via will cause any reliability issue? is it not recommended to do this this method ?
Regards
Jithindev MK
  • RFinley
    RFinley over 4 years ago +3 verified
    Coincident over mechanical drills will be a yield problem if you don't pay for filled/planarized/plated core vias. Extra processing steps to minimize risk of opens. Talk to your fabricator. Even If you…
  • masamasa
    masamasa over 4 years ago +3 verified
    stacked vias may cause reliability issues such as cracks. so determining the diameter of vias and catch pads is a key to pass the reliability tests.
  • JuanCR
    0 JuanCR over 4 years ago
    Hi Jithindev. Can you elaborate a bit more? Do you just want to know if stacking a micro via on top of a BB via is not a recommended practice?
  • JITHINDEV
    0 JITHINDEV over 4 years ago in reply to JuanCR
    Hi JuanCR,
    Yes, can you explain what issue may occur on stacking micro via over buried via.
    image attached
    Cheers
    Jithindev
  • RFinley
    +1 RFinley over 4 years ago
    Talk to your fabricator.  Even If you have just one as coincident, you really need to pay for planarization.
    • Vote Up +3 Vote Down
  • masamasa
    +1 masamasa over 4 years ago
  • JITHINDEV
    0 JITHINDEV over 4 years ago in reply to masamasa
    Hi masamasa,Can you elaborate a bit more.
    Cheers
    Jithindev MK
