  3. When i click on any component in PCB Editor, capture invokes...
  • Views 11145
When i click on any component in PCB Editor, capture invokes automatically
Apexter
Apexter over 4 years ago
I recently came across an issue in PCB Editor. When both Capture and PCB Editor tools are invoked, if i click on any component in PCB Editor automatically the window is shifted to Capture Canvas indicating that component. What may be the cause of the issue.
I am using OrCAD PCB Designer professional S032
  • mahimag
    mahimag over 4 years ago +1
    This feature is called as Cross Probing, when both Capture and PCB Editor are connected in same session you can cross probe between 2 tools using Inter Tool Communication. You can disable this using…
  • mahimag
    0 mahimag over 4 years ago
    You can disable this using the below steps in Capture:
    1. Choose Option – Preferences.
    2. In the Preferences dialog box, select the Miscellaneous tab.
    3. Uncheck the Enable Intertool Communication check box.
    4. Click OK.
  • Apexter
    0 Apexter over 4 years ago in reply to mahimag
    Hi mahimag,
    I am aware about the ITC feature in OrCAD as i have been using this feature from quite a long time. My concern is about the automatic window switch from PCB Editor to Capture which i haven't observed till now while using the tool with ITC feature enabled.
