  3. Cadence 17.4 S019 has shorts appearing on copper pours
  • Views 9491
tmd63
tmd63 over 4 years ago
I have an inner layer which is a ground plane and there are microvias going through this.
But when I check the copper pour. It has shorted out some pins! There is no DRC error I and would have to search 4000+ connections to see if the plane has shorted.
I must use a hatch plane. a solid plane does not short but it is a requirement of the design.
  • DavidJHutchins
    0 DavidJHutchins over 4 years ago
    Instead of using a hatch plane, could you use a solid plane with a matrix pattern of voids like the image below?
  • tmd63
    0 tmd63 over 4 years ago in reply to DavidJHutchins
    The problem with this how would you set each via as to not have undercuts? How would you set the area to cover a PWB that is 14 inches long and 1.75 inches wide but avoid all through pins and vias? This is where a hatched shape performs greatly, normally!
