  3. allegro assembly drawing and pick n place exportation for...
  • Views 10760
allegro assembly drawing and pick n place exportation for variant excluding not fitted parts
frank mpbc
frank mpbc over 4 years ago
In Capture, I made a variant where I marked parts as "not present" (not fitted). In Allegro, I enable the assembly layer visibility and export a DXF. Is there an automatic way to remove the parts that are marked as not present, or put an X on them?
Also, in the pick n place report, is there an automatic  way to mark the unfitted parts, or just delete the rows for unfitted parts?
I use Allegro 17.4.
Thank you,
  • steve
    0 steve over 4 years ago
    You can generate a variant.lst file from capture that can be used in Allegro. Look at Manufacture - Variants - Create Assembly Drawing which takes the variant.lst file and generates a new subclass in manufacturing that can then be exported using dxf. To generate the variant.lst open Capture CIS - Part Manager and use Tools - Export variant list.
  • Schulz Jordan
    0 Schulz Jordan over 3 years ago
    Use Manufacture - Variants - variant assembly drawings
