  3. Dynamic Mode disabled / gray in teardrops parameters
  • Views 9840
MarkSchw85
MarkSchw85 over 4 years ago
maybe someone can help me with my problem.
I am not able to activate the dynamic mode in the teardrops parameters. its gray. what could be the reason?
thank you very much for you support
BR, Markus
  • steve
    0 steve over 4 years ago
    Its license related, if you have Allegro PCB Designer or higher you can enable these to be dynamic, if you have an OrCAD Professional license you can't and have to apply them using a window select or pick each net/pin/via you want.
