  3. Find all the pins between two X coordinates
  • State Suggested Answer
  • Answers 1
  • Views 9591
ANNAY
ANNAY over 4 years ago
I'm looking for specific pins that are located between two known x coordinates. Is there a command that can give me a list of all those pins?
I'm looking for an easier way to extract them besides counting and writing their pin names manually.
Thanks!
Anna
  • DavidJHutchins
    0 DavidJHutchins over 4 years ago
    I wrote a simple skill routine to return a list of pins winthin a box/window, below is the journal file showing it's usage:
    \i (00:00:08) generaledit
    \i (00:00:16) skill
    \i (00:00:43) skill 'load("get_pins_between.ils")'
    (00:00:43) t
    \i (00:01:02) skill 'pp get_pins_between'
    (00:01:02) procedure(get_pins_between(minx miny maxx maxy "nnnn")
    (00:01:02) let((OnButtonList EnabledList bBox PinList)
    (00:01:02) (OnButtonList = axlGetFindFilter())
    (00:01:02) (EnabledList = axlGetFindFilter(t))
    (00:01:02) axlClearSelSet()
    (00:01:02) axlSetFindFilter(?enabled
    (00:01:02) list("noall" "pins" "invisible") ?onButtons
    (00:01:02) list("noall" "pins")
    (00:01:02) )
    (00:01:02) (bBox = list((minx:miny)
    (00:01:02) (maxx:maxy)
    (00:01:02) ))
    (00:01:02) axlAddSelectBox(bBox)
    (00:01:02) (PinList = axlGetSelSet())
    (00:01:02) axlSetFindFilter(?enabled EnabledList ?onButtons OnButtonList)
    (00:01:02) PinList
    (00:01:02) )
    (00:01:02) )
    (00:01:02) nil
    \i (00:01:33) skill 'PinList = get_pins_between( 1525 950 1650 1850)'
    (00:01:33) (dbid:0000002D6197F950 dbid:0000002D6197F880 dbid:0000002D6197C190 dbid:0000002D6197F7B0 dbid:0000002D6197BEB0
    (00:01:33) dbid:0000002D6197B9F0 dbid:0000002D6197CE20 dbid:0000002D6197BDE0 dbid:0000002D6197EF30 dbid:0000002D6197CEC0
    (00:01:33) dbid:0000002D6197EE90 dbid:0000002D6197EDF0 dbid:0000002D6197ED50 dbid:0000002D6197E490 dbid:0000002D6197F6E0
    (00:01:33) dbid:0000002D6197D100 dbid:0000002D6197DAB0 dbid:0000002D6197D030 dbid:0000002D6197D1A0 dbid:0000002D6197ECB0
    (00:01:33) dbid:0000002D6197E3F0 dbid:0000002D6197E350 dbid:0000002D6197E2B0 dbid:0000002D6197BB30 dbid:0000002D6197BD10
    (00:01:33) dbid:0000002D6197EC10 dbid:0000002D6197C020 dbid:0000002D6197C0C0 dbid:0000002D6197EB70 dbid:0000002D619892C8
    (00:01:33) dbid:0000002D61989228 dbid:0000002D6197CD50
    (00:01:33) )
    \i (00:01:50) skill 'foreach(pin PinList axlMsgPut("pin name %s (%f %f)" pin->name car(pin->xy) cadr(pin->xy)))'
    \t (00:01:50) pin name SMD65REC13 (1580.000000 1048.000000)
    \t (00:01:50) pin name SMD65REC13 (1580.000000 1074.000000)
    \t (00:01:50) pin name SMD65REC13 (1580.000000 1100.000000)
    \t (00:01:50) pin name SMD65REC13 (1580.000000 1126.000000)
    \t (00:01:50) pin name SMD65REC13 (1580.000000 1152.000000)
    \t (00:01:50) pin name SMD65REC13 (1580.000000 1178.000000)
    \t (00:01:50) pin name SMD65REC13 (1580.000000 1204.000000)
    \t (00:01:50) pin name SMD65REC13 (1580.000000 1230.000000)
    \t (00:01:50) pin name SMD65REC13 (1580.000000 1256.000000)
    \t (00:01:50) pin name SMD65REC13 (1580.000000 1438.000000)
    \t (00:01:50) pin name SMD65REC13 (1580.000000 1464.000000)
    \t (00:01:50) pin name SMD65REC13 (1580.000000 1490.000000)
    \t (00:01:50) pin name SMD65REC13 (1580.000000 1516.000000)
    \t (00:01:50) pin name SMD65REC13 (1580.000000 1282.000000)
    \t (00:01:50) pin name SMD65REC13 (1580.000000 1308.000000)
    \t (00:01:50) pin name SMD65REC13 (1580.000000 1334.000000)
    \t (00:01:50) pin name SMD65REC13 (1580.000000 1360.000000)
    \t (00:01:50) pin name SMD65REC13 (1580.000000 1386.000000)
    \t (00:01:50) pin name SMD65REC13 (1580.000000 1412.000000)
    \t (00:01:50) pin name SMD65REC13 (1580.000000 1542.000000)
    \t (00:01:50) pin name SMD65REC13 (1580.000000 1568.000000)
    \t (00:01:50) pin name SMD65REC13 (1580.000000 1594.000000)
    \t (00:01:50) pin name SMD65REC13 (1580.000000 1620.000000)
    \t (00:01:50) pin name SMD65REC13 (1580.000000 1646.000000)
    \t (00:01:50) pin name SMD65REC13 (1580.000000 1672.000000)
    \t (00:01:50) pin name SMD65REC13 (1580.000000 1698.000000)
    \t (00:01:50) pin name SMD65REC13 (1580.000000 1724.000000)
    \t (00:01:50) pin name SMD65REC13 (1580.000000 1750.000000)
    \t (00:01:50) pin name SMD65REC13 (1580.000000 1776.000000)
    \t (00:01:50) pin name SMD50_87 (1580.000000 1570.000000)
    \t (00:01:50) pin name SMD50_87 (1580.000000 1765.000000)
    \t (00:01:50) pin name SMD65REC13 (1580.000000 1802.000000)
    (00:01:50) (dbid:0000002D6197F950 dbid:0000002D6197F880 dbid:0000002D6197C190 dbid:0000002D6197F7B0 dbid:0000002D6197BEB0
    (00:01:50) dbid:0000002D6197B9F0 dbid:0000002D6197CE20 dbid:0000002D6197BDE0 dbid:0000002D6197EF30 dbid:0000002D6197CEC0
    (00:01:50) dbid:0000002D6197EE90 dbid:0000002D6197EDF0 dbid:0000002D6197ED50 dbid:0000002D6197E490 dbid:0000002D6197F6E0
    (00:01:50) dbid:0000002D6197D100 dbid:0000002D6197DAB0 dbid:0000002D6197D030 dbid:0000002D6197D1A0 dbid:0000002D6197ECB0
    (00:01:50) dbid:0000002D6197E3F0 dbid:0000002D6197E350 dbid:0000002D6197E2B0 dbid:0000002D6197BB30 dbid:0000002D6197BD10
    (00:01:50) dbid:0000002D6197EC10 dbid:0000002D6197C020 dbid:0000002D6197C0C0 dbid:0000002D6197EB70 dbid:0000002D619892C8
    (00:01:50) dbid:0000002D61989228 dbid:0000002D6197CD50
    (00:01:50) )
    \i (00:01:59) skill exit
    (00:01:59) t
    \i (00:02:02) exit
    \e (00:02:02) Do you want to save the changes you made to cds_routed.brd?
    \i (00:02:03) fillin no
    \t (00:02:03) Journal end - Sun Nov 13 10:24:04 2022
  • DavidJHutchins
    0 DavidJHutchins over 4 years ago in reply to DavidJHutchins
    skill code included below:
    procedure(get_pins_between(minx miny maxx maxy) let((OnButtonList EnabledList bBox PinList) (OnButtonList = axlGetFindFilter()) (EnabledList = axlGetFindFilter(t)) (axlClearSelSet) (axlSetFindFilter ?enabled (list "noall" "pins" "invisible") ?onButtons (list "noall" "pins")) (bBox = axlExtentDB('obstacle)) unless(minx (minx = caar(bBox)) ) unless(minx (minx = cadar(bBox)) ) unless(maxx (maxy = caadr(bBox)) ) unless(maxy (maxy = cadadr(bBox)) ) (bBox = list((minx:miny) (maxx:maxy))) axlAddSelectBox(bBox) (PinList = (axlGetSelSet)) (axlClearSelSet) (axlSetFindFilter ?enabled EnabledList ?onButtons OnButtonList) PinList ) )
