  3. PCB Editor 17.4 INCREDIBLY SLOW, 17.2 OK
  • State Verified Answer
  • Replies 7
  • Subscribers 166
  • Views 15889
mlelek94
mlelek94 over 4 years ago
Hi there,
I just get newer version of OrCAD PCB Designer - 17.4 instead of 17.2 (due to reinstalling my laptop - W10 crashed, reinstalled to 22H2 from previous 21H2). Version 17.2 was fine, without any signs of high system load, but in version 17.4 it seems that there is some problem with graphical interface - when I slide with cursor over the objects on the board, normally in 17.2 every object will highlight and de-highlight immediatelly with cursor current position, but in 17.4 it does not - there is a delay about half second, which is annoying and makes PCB Designer more or less unusable.. What's more, the power usage on CPU (w integrated graphics - i5 8265U, 8G of RAM) rises up to 100% percent. Does anyone know how to fix this issue?
Thanks for response!
  • excellon1
    excellon1 over 3 years ago in reply to mlelek94 +1 verified
    The issue is the pcb editor, not the version of windows you are using nor OpenGl. Years back I had posted about this. So some background. The most like version of 17.4 to 17.2 for graphics speed is any…
  • excellon1
    +1 excellon1 over 3 years ago in reply to mlelek94
    The issue is the pcb editor, not the version of windows you are using nor OpenGl. Years back I had posted about this. So some background. The most like version of 17.4 to 17.2 for graphics speed is any version of 17.4 up to service pack 8. When service pack 8 was introduced it came with some new features. One of them was Dark Theme as up until that point the pcb editor did not have it but it did have the modern icons. In the versions up to service pack 8 there is no delay in highlighting any object. It works just like in 17.2.
    If you look back at prior posts one user indicated that the way the highlighting in 17.4 works was actually a feature as indicated by their German Var as I recall. This so called feature appeared out of "No-Where" there was no mention of it in any CCR.
    It has been some time since 17.4 was released and the lack of speed in highlighting any object remains. There is no fix to this in any service pack other than mentioned above.
  • mlelek94
    0 mlelek94 over 3 years ago in reply to excellon1
    Thanks a lot! So we decided to downgrade to SP7 of PCB Designer 17.4 and problem disappeares - this OrCAD version has fast highlighting response with moving cursor. You saved my psychical health condition, in the future we will see, if CADENCE will f* back this ELEMENTARY functionality.
