  3. PCB Editor 17.4 INCREDIBLY SLOW, 17.2 OK
  • State Verified Answer
  • Replies 7
  • Subscribers 166
  • Views 15888
mlelek94
mlelek94 over 4 years ago
Hi there,
I just get newer version of OrCAD PCB Designer - 17.4 instead of 17.2 (due to reinstalling my laptop - W10 crashed, reinstalled to 22H2 from previous 21H2). Version 17.2 was fine, without any signs of high system load, but in version 17.4 it seems that there is some problem with graphical interface - when I slide with cursor over the objects on the board, normally in 17.2 every object will highlight and de-highlight immediatelly with cursor current position, but in 17.4 it does not - there is a delay about half second, which is annoying and makes PCB Designer more or less unusable.. What's more, the power usage on CPU (w integrated graphics - i5 8265U, 8G of RAM) rises up to 100% percent. Does anyone know how to fix this issue?
Thanks for response!
  • excellon1
    excellon1 over 3 years ago in reply to mlelek94 +1 verified
    The issue is the pcb editor, not the version of windows you are using nor OpenGl. Years back I had posted about this. So some background. The most like version of 17.4 to 17.2 for graphics speed is any…
  • mlelek94
    0 mlelek94 over 3 years ago
    Anybody here to response??
  • DavidJHutchins
    0 DavidJHutchins over 3 years ago
    Are you using Windows 10 version 22H2 or Windows 11 version 22H2?
    The Win 11 update has major issues with Nvidia devices...
  • FormerMember
    0 FormerMember over 3 years ago in reply to DavidJHutchins
    Dave
    We were told Cadence does not support Windows 11 yet ?
    Les
  • Schulz Jordan
    0 Schulz Jordan over 3 years ago in reply to FormerMember
    Disable opengl which minimizes graphics usage. Recommended by cadence is to have an external graphics of min 2GB. Also make sure you meet minimum specs requirement for 17.4
    • Vote Up -1 Vote Down
  • mlelek94
    0 mlelek94 over 3 years ago in reply to Schulz Jordan
    I am using W10 22H2 version. I tried to disable OpenGL in PCB editor, so after app restart the transparency in design disappeared, but slowness with objects highlighting under moving cursor still persists. One interesting point - this slowness is not affected with design complexity at all - it happens in the same way on board with two components or on board with two thousand components, so I think this does not have any to do directly with graphics card hardware. And I don't think that something really special, big and power-consuming happened between 17.2 to 17.4 designer version.
