  3. Can I edit/import .drl files?
  • State Verified Answer
  • Views 4092
cveen
cveen over 3 years ago
I found a lot of (very old) posts saying that I can't... but now we're on allegro 17.4. Is it still not possible?
Background / why do I want to do this:
We have a design that is spread over 2 boards. We'd like to try getting it printed with Digikey Red, but their system won't allow multi-board jobs (I guess it's automated? In any case they reject it). So I'd like to "chop up" the fab files such that I have 2 sets of art files and drl files - one for each board. It seems like this should be "easy". Fab houses do this sort of thing all the time, for example to panelize.
Trying to delete things in a copy of the complete design file seems to be a black-hole of problems - maybe it wasn't the "right" way to do it, but I've got the keepins/outs defined as part of a mechanical symbol that is *both* boards together (they fit in the same enclosure, and would always be used as a pair). Now this effectively prevents that avenue. Possibly I could create new symbols for each board, but I'm starting to worry about all the DRCs that I'm going to have to ignore and worried about mistakes when the dynamic copper kicks in.
So I start a new project and import each art file into appropriate layers. This seems to work great - there's no components and the dynamic copper, traces, everything are just shapes I can do whatever I want with and I don't need to worry about anything changing in strange ways. But I can't seem to get the .drl file into allegro in order to do the same for the holes.
Is it possible to import .drl files? If not, any suggestions on the best way to solve this problem?
Thanks!
  • DavidJHutchins
    DavidJHutchins over 3 years ago +1 verified
    Allegro doesn't have the ability to import the .drl or .rou manufacturing files :( However, a possible limited solution would be to generate a 'drill' artwork file containing 'Pin/Top' & 'Via Class/Top…
  • DavidJHutchins
    +1 DavidJHutchins over 3 years ago
    However, a possible limited solution would be to generate a 'drill' artwork file containing 'Pin/Top' & 'Via Class/Top' with the 'draw holes only' option that was recently added
    The limitation is that the plated/non-plated data is missing and this does not handle buried/blind or backdrilling holes Disappointed
  • cveen
    0 cveen over 3 years ago in reply to DavidJHutchins
    Thanks for the confirmation. Since the .drl file is plain-text and (more-or-less) easy to read I ended up writing a python script to read it, partition based on the x co-ordinate, and re-write new files and headers. Fortunately my design didn't have any "R" (repeated evenly-spaced holes) commands between boards...
