  3. using DFA Spread sheet in OrCAD 17.4 Professional
  • State Verified Answer
  • Subscribers 166
  • Views 11029
JITHINDEV
JITHINDEV over 3 years ago
Hi all,
Is it possible to load DFA spread sheet in OrCAD 17.4 Professional.
Thanks and regards,
Jithindev MK
  • digital1
    digital1 over 3 years ago +1
    Hi Jithindev, I think what you are looking for is explained in this video on youtube from parallel systems cadence reseller in the uk Cadence PCB Design For Assembly Checks - YouTube in particular…
  • DavidJHutchins
    +1 DavidJHutchins over 3 years ago
    No, the command doesn't exist with that license
  • JITHINDEV
    0 JITHINDEV over 3 years ago in reply to DavidJHutchins
    Hi DavidJHutchins, Thankyou for the reply, OrCad 17.4  professional is providing DFA spread sheet externally, Not with the PCB editor tool. whether we can assign the DFA values externally to the editor ?
    Thanks and regards,
    Jithindev MK
  • RFinley
    0 RFinley over 3 years ago in reply to JITHINDEV
    The problem is DFA is not part of Orcad.
    You won't be able import and run DFA DRCs without a base Allegro license.
  • digital1
    0 digital1 over 3 years ago
    Hi Jithindev,
    in particular look at the video from about 3 minutes and 40 seconds
