  3. Background color change Cadence PCB viewer?
  • State Verified Answer
  • Subscribers 161
  • Views 13773
Silvast
Silvast over 3 years ago
I found a board file where the background is not Black.
How do I change this in Capture Viewer?
  • JITHINDEV
    0 JITHINDEV over 3 years ago
    Hi Silvast, Follow the below steps
    Display>>Color/visibility (open color dialog)
    In Display tab you can change the background color.
    cheers
    Jithindev
  • Silvast
    0 Silvast over 3 years ago in reply to JITHINDEV
    I cannot find this setting in "Allegro Free Physical Viewer"  22.1
  • DavidJHutchins
    +1 DavidJHutchins over 3 years ago in reply to Silvast
    in the View menu enable the 'Command' setting
    Then at the Command>  prompt enter color192
    then in the Dipslay tab you can change the background color
  • DavidJHutchins
  • Silvast
    0 Silvast over 3 years ago in reply to DavidJHutchins
    That worked!
  • SimpleFix
    0 SimpleFix 11 months ago in reply to DavidJHutchins
    Thank you. This was very helpful. I like to change the background to white when printing snapshots of the layout to make modification drawings for the technician, so I don't waste tons of toner with a black background. I wish the background color option wasn't so hidden as to require a command to display.
