  3. Exporting Custom IPC-356 Netlist option in Allegro (PCB...
  • Views 10290
Exporting Custom IPC-356 Netlist option in Allegro (PCB Editor)
RagavanT
RagavanT over 3 years ago
Is there any option to export Layer defined IPC netlist option in Cadence Allegro? my requirement is Board consist of XX layers but i wan to export the IPC netlist for by skipping X layers. Thanks in advacne.
  • excellon1
    excellon1 over 3 years ago +1
    Hi it is not possible to do this as the IPC Netlist option will export all nets in the design. The netlist for any PCB Cad software just shows the node information or electrical connectivity between pins…
  • excellon1
    Hi it is not possible to do this as the IPC Netlist option will export all nets in the design. The netlist for any PCB Cad software just shows the node information or electrical connectivity between pins. The physical connection in copper could be on any layer. Basically the layers have no relation to the netlist at all. Another way to think about it is a netlist is just a point to point map. How you actually connect that map does not matter.
