  3. Allegro - Tip of the Week: Route Cleanup
  • Views 3423
PCBTech
PCBTech over 3 years ago
For detecting scenarios such as non-ideal pad entry, short segments, 90-degree corners, or non-arc corners, consider the Route Vision application.
The Vision Manager displays selected nets or segments as a result of an analysis or DRC using color codes.
First, enable the Vision Manager (View > Vision Manager). Then, in the Options pane, select the “Visions” tab and pick Route Vision from the pull-down menu.
Configure your settings and then click OK to invoke the command.
Team PCBTech
Cadence Design Systems
  • JakeBarrows
    JakeBarrows over 3 years ago +1
    Love the tip! We are operating on Standard edition, is this only a function in the Professional version? I only see "No Vision" in the dropdown on the Visions page
  • JakeBarrows
  • TCHA
    TCHA over 3 years ago in reply to JakeBarrows
    Yes, the Vision Manager utility is available in the Orcad PCB Designer Professional license only. It is not available in the Standard license.
  • JakeBarrows
    JakeBarrows over 3 years ago in reply to TCHA
    That's disappointing. I appreciate your swift response though!
