  3. extracta multi-views into 1 output file
  • Views 8995
HJerry
HJerry over 3 years ago
Hi all,
Is there a way to get multi-views output into one output file?
Here is my view file:
BOARD
BOARD_DFA_DEV_CLASS
END
GEOMETRY
PACKAGE_HEIGHT_MAX
END
I haven't used extracta in a long time and can't remember if this is possible.
extracta -t 0603.dra test.txt output1
--Jerry
  • JuanCR
    0 JuanCR over 3 years ago
    what do you mean by multi-views output?
  • HJerry
    0 HJerry over 3 years ago in reply to JuanCR
    There a two views, BOARD and GEOMETRY. I was wanting to get both outputs into one file.
    I worked around it using PERL.
