  3. Why is the stock padstack hole120 show 12000mils?
  • Views 8906
ajawamnet
ajawamnet over 3 years ago
Riddle me this one - why does the stock padstack Hole120.pad have a drill callout of 12000 mil?  it places in Package Designer as a 120mil pad.  No other hole I can find does this.
This is a fresh installation of 17.4... see vid  https://youtu.be/NzqBMAk66A8
    0 Andrew Beckett over 3 years ago
    I can't answer the technical question (I'm a moderator for some of the other forums and Allegro is not my product area). I saw this one stuck in moderation as it was detected as potential spam - that was because you posted with a YouTube video link - it just needs checking before the post is approved (I'm sure you'll have noticed the level of spam posts on the forums has gone down a lot recently, but unfortunately the penalty is that it catches a few posts that are genuine; once appealed though, we'll generally let the post through if it seems valid).
  • DavidJHutchins
    0 DavidJHutchins over 3 years ago
    The 'Padstack Definition' report on that padstack reports the hole size as 120.00 mils, not sure where you are getting 12000 mils
    D:\Cadence\SPB_17.4\share\pcb\pcb_lib\symbols>report -v pad hole120.pad
    Report written to D:/Cadence/SPB_17.4/share/pcb/pcb_lib/symbols/pad_rep.rpt
    D:\Cadence\SPB_17.4\share\pcb\pcb_lib\symbols>type pad_rep.rpt
    Padstack Definition Report
    D:/Cadence/SPB_17.4/share/pcb/pcb_lib/symbols/hole120.pad
    Thu Dec 29 08:46:43 2022
    Total Padstack Definitions: 1
    Dimensions in mils with 2 decimal places
    Padstack: HOLE120 Type: Through Inner pads: Fixed
    Layer,Pad Type,Geometry,Width,Height,Offset X,Offset Y,Flash Name,Shape Name,Trim/Sides,Value
    BEGIN LAYER,ANTI,NULL,0.00,0.00,0.00,0.00,,,,0.00
    BEGIN LAYER,THERMAL,NULL,0.00,0.00,0.00,0.00,,,,0.00
    BEGIN LAYER,REGULAR,CIRCLE,130.00,130.00,0.00,0.00,,,,0.00
    BEGIN LAYER,KEEPOUT,NULL,0.00,0.00,0.00,0.00,,,,0.00
    END LAYER,ANTI,NULL,0.00,0.00,0.00,0.00,,,,0.00
    END LAYER,THERMAL,NULL,0.00,0.00,0.00,0.00,,,,0.00
    END LAYER,REGULAR,CIRCLE,130.00,130.00,0.00,0.00,,,,0.00
    END LAYER,KEEPOUT,NULL,0.00,0.00,0.00,0.00,,,,0.00
    internal_pad_def,ANTI,NULL,0.00,0.00,0.00,0.00,,,,0.00
    internal_pad_def,THERMAL,NULL,0.00,0.00,0.00,0.00,,,,0.00
    internal_pad_def,REGULAR,CIRCLE,120.00,120.00,0.00,0.00,,,,0.00
    internal_pad_def,KEEPOUT,NULL,0.00,0.00,0.00,0.00,,,,0.00
    SOLDERMASK_TOP,REGULAR,CIRCLE,140.00,140.00,0.00,0.00,,,,0.00
    SOLDERMASK_BOTTOM,REGULAR,CIRCLE,140.00,140.00,0.00,0.00,,,,0.00
    PASTEMASK_TOP,REGULAR,NULL,0.00,0.00,0.00,0.00,,,,0.00
    PASTEMASK_BOTTOM,REGULAR,NULL,0.00,0.00,0.00,0.00,,,,0.00
    FILMMASKTOP,REGULAR,NULL,0.00,0.00,0.00,0.00,,,,0.00
    FILMMASKBOTTOM,REGULAR,NULL,0.00,0.00,0.00,0.00,,,,0.00
    layer adjacent KO,REGULAR,NULL,0.00,0.00,0.00,0.00,,,,0.00
    COVERLAY_TOP,REGULAR,NULL,0.00,0.00,0.00,0.00,,,,0.00
    COVERLAY_BOTTOM,REGULAR,NULL,0.00,0.00,0.00,0.00,,,,0.00
    Drill Data for HOLE120
    Hole Type,Drill Dia,Plating,Figure,Characters,Width,Height,Offset X,Offset Y,Pos Tolerance,Neg Tolerance,Non-Standard
    CIRCLE_DRILL,120.00,PLATED,CIRCLE,,123.00,123.00,0.00,0.00,0.00,0.00,STANDARD
