  3. High Resolution Display with Virtuoso
  • Views 13194
jdsherman
jdsherman over 3 years ago
Recently switched to a high resolution display for use with Virtuoso. As usual when switching to a 4k display, the fonts and icons are all way too small. I tried the following solution:
In .bashrc:
export CDS_2DFORM_FONT_SCALING=1
In my .cdsinit:
hiSetFont("<ciw, text, or label" ?size <font_size>)
The text becomes mostly readable, but it doesn't scale the windo or panel size - this makes aspects such as the assistants in layout challenging to use. Is there a better method to scale the application for a 4k monitor?
Thanks!
  • Dziner
    0 Dziner over 3 years ago
    This is what I did when I had Display Scaling issue with Allegro.
    Navigate to the Allegro.exe location,
    C:\Cadence\SPB_17.2 or SPB_17.4\tools\bin\allegro.exe
    And change the settings as below.
    Right click allegro.exe → Properties → Compatibility tab → Change high DPI settings → Select the Override high DPI scaling behavior check box. Then click the Application drop-list arrow and select System.
    Try and see if this helps.
  • jdsherman
    0 jdsherman over 3 years ago in reply to Dziner
    Thanks! I'm unfortunately running Virtuoso on a Linux platform, so the Windows method won't work for me
