  3. Purging or Clearing Existing Constraints in an Allegro Board...
  • State Verified Answer
  • Views 11714
Purging or Clearing Existing Constraints in an Allegro Board File
cstocci52
cstocci52 over 3 years ago
Folks,
Is there an easy and simple way to purge all of the existing constraints in an existing Allegro layout?  I get boards from previous bureaus that have a ton of constraints and it takes me a fair amount of time to clear them out before I can do my thing.  I am running spb 17.40, but I get Allegro versions back to 16.3 to deal with many times.
Thanks!
  • Daniel
    Daniel over 3 years ago +1
    Tool>Database check>Purge unused constrain
  • DavidJHutchins
    DavidJHutchins over 3 years ago in reply to Daniel +1 verified
    The easiest way I have found to remove all the constraints in a design is to: 1. First open a new board file, then open Constraint Manager & export it's constraints using the Generic cross-section …
  • Daniel
    0 Daniel over 3 years ago
  • DavidJHutchins
    +1 DavidJHutchins over 3 years ago in reply to Daniel
    2. Then open the existing board file, then open Constraint Manager & import the last saved constraints using the Override Import Mode
