  3. Allegro PCB Router quit unexpectedly with an exit code of...
  • State Suggested Answer
  • Replies 7
  • Answers 1
  • Subscribers 163
  • Views 14106
Allegro PCB Router quit unexpectedly with an exit code of 1
Jartigas
Jartigas over 3 years ago
When I try Route --> PCB Router --> Route automatic, I am getting
 Allegro PCB Editor quit unexpectedly with an exit code of 1. Please verify that you are running SPECCTRA version V9.0 or later.
How I can repair this? The specftra log says I dont have license, but I have it.
specctra.log:
#                               Allegro PCB Router
# Copyright 1990-2010 Cadence Design Systems, Inc.  All Rights Reserved.
# Software licensed for sale by Cadence Design Systems, Inc.
# Current time = Thu Jan 19 13:35:49 2023
# Allegro PCB Router v22-1-0 made 2022/08/17 at 12:48:59
# Running on: xxxxxx, OS Version: WindowsNT 6.2.9200, Architecture: Intel Pentium II, III, or 4
# Licensing: The program will not obey any unlicensed rules
# No graphics will be displayed.
# Design Name C:/Users/jartigas/Desktop/AE-3660/allegro\ae-3660.dsn
# Batch File Name: pasde.do
# Did File Name: C:/Users/jartigas/Desktop/AE-3660/allegro/specctra.did
# <<WARNING:>> Please contact your system administrator for licensing support.
# Licensing Error:
# No License file found: Entering Demo Mode: NO SAVES PERMITTED!
# License Not Found: Entering Demo Mode. Saves WILL NOT be permitted!
# 0) OK,
# 1) EXIT
# Choose one:
Regards.
  • mahimag
    mahimag over 3 years ago in reply to Jartigas +1 suggested
    Hello Jartigas , if the variable LM_LICENSE_FILE is not set then it is ok, I wanted to check this in order to make sure that it is not pointing to any non-Cadence license servers. Are you faicng the issue…
  • mahimag
    0 mahimag over 3 years ago
    You can check LM_LICENSE_FILE and CDS_LIC_FILE variables and if both are pointing to different servers, set CDS_LIC_ONLY = TRUE, this will make most of the Cadence applications to look at the license servers defined in the CDS_LIC_FILE environment variable.
  • Jartigas
    0 Jartigas over 3 years ago in reply to mahimag
    Hello mahimag, thank you for you support.
    I haven´t LM_LICENSE_FILE variable in system variables (this is OK?). I have CDS_LIC_FILE and CDS_LIC_ONLY = 1 (I have changed 1 to TRUE, with the same result).
    Where can I see LM_LICENSE_FILE?.
    Regards.
  • mahimag
    0 mahimag over 3 years ago in reply to Jartigas
    Hello Jartigas, if the variable LM_LICENSE_FILE is not set then it is ok, I wanted to check this in order to make sure that it is not pointing to any non-Cadence license servers. Are you faicng the issue? If yes, can you share the license you are using to run AutoRouter?
  • Jartigas
    0 Jartigas over 2 years ago in reply to mahimag
    Hello mahimag, how can I solve the problem?
  • mahimag
    0 mahimag over 2 years ago in reply to Jartigas
    Hello Jartigas , can you try to remove the special character "-" in name of design and design location
     For example, In the below location and name, AE-3660 has "-" as special character.
