  3. dbdoctor error, problem with environment variables?
  • State Verified Answer
  • Subscribers 167
  • Views 14604
atbc
atbc over 3 years ago
 I'm evaluating a reference design for the Atmel SAM3X (link) but when attempting to open the BRD file with OrCAD PCB Designer Professional 17.4-2019 S026, I get:
So,
C:\Temp>%dbdoctor% .\SAM3X-EK_REVB.brd
Can't open environment file: C:/share/text/env
pcell_lib_path: Variable not defined
Parse error in file C:/CADENCE/SPB_DATA/pcbenv/env, line 10
Unable to find the messaging system module definitions file 'allegro_smi_modules.txt'
ERROR: Could not initialize the Allegro error messaging system.
That path to the environment file is odd because,
  1. it's as if C:\ has been assigned root
  2. there is no \text\ directory in C:\Cadence\SPB_17.4\share\
  3. the env file I edit resides at C:\Cadence\SPB_17.4\share\pcb\text\env
Then the following lines are odd because the pcell_lib_path variable is, in fact, defined in C:/CADENCE/SPB_DATA/pcbenv/env, line 10
My user variable for HOME is set to C:\CADENCE\SPB_DATA\ and I have read that CDS_ROOT is not necessary for a single version 17 install, am I missing some other magic environment variable?
  • steve
    steve over 3 years ago +1 verified
    This is because you are running via a DOS command prompt. You need to create a new windows environment variable called CDSROOT with a value of C:\Cadence\SPB_17.4. You also need to include the following…
  • steve
    +1 steve over 3 years ago
    This is because you are running via a DOS command prompt. You need to create a new windows environment variable called CDSROOT with a value of C:\Cadence\SPB_17.4. You also need to include the following in the PATH variable %CDSROOT%\tools\bin then try again. You could also try running PCB DBDoctor 17.4 from the start menu. There is an app....
  • atbc
    0 atbc over 3 years ago in reply to steve
    You're the best Steve, thanks!
  • Sriramoju
    0 Sriramoju over 3 years ago in reply to steve
    I didn't get your point. Can you please explain elaborately.
