  3. Pads ASC Import Silkscreen Issues
  • State Suggested Answer
  • Answers 1
  • Views 9584
Skwidder
Skwidder over 3 years ago
When I try to import a PADs .asc file into Orcad PCB Designer useing the tool the silkscreen always come out messed up. Incorrect sizes, placement, and sometimes rotation.
Here is a small example:
Pads PCB Layout Viewer
Orcard PCB after import:
I have messed around with what layers map to what orcad layers but nothing seems to fix the issue, and even if i did have the layers wrong why would some be rotated. All the above silkscreen is on the top layer, so I don't get why some of the text would flip.
Any help is very much appreciated.
  • RFinley
    RFinley over 3 years ago +1 suggested
    I do my place/route in Allegro but translate back to P*DS for engineers to review it. CIS for design capture. Yeah, I know. You're seeing the default Orcad/Allegro silkscreen designator locations. …
  • RFinley
    0 RFinley over 3 years ago
    Allegro has Autosilk.  Part labels are handled completely different between them.
    I'd suggest DXF except P*Ds DXF export is a bit random.  Because it's assembly silk, I would just update manually.  Push back on an exact duplication.
