  3. How to manage copper thickness + plating in STACK-UP by...
  • State Suggested Answer
  • Answers 1
  • Views 9444
How to manage copper thickness + plating in STACK-UP by DFM Wizard?
SorinTodorut
SorinTodorut over 3 years ago
Hello everyone,
Right now is possible only to add base copper + copper plating in STACK-UP.
If I use the DFM True Wizard to work properly I only need the base cooper thickness in STACK-UP. The issue is that DFM wizard only takes the value from the STACK-UP which is not correct since it is base cooper+ copper plating.
If i add plating in the external cooper DFM Wizard automatically assigns a wrong value following the total thickness defined (copper + plating) not only the base copper.
How to manage copper thickness + plating in STACK-UP by DFM True Wizard?
Thank you in advance.
Best Regard,
Sorin
  • Elecguy
    0 Elecguy over 3 years ago
    If you have access to COS, there is a documenta called "Modifying DesignTrue DFM Wizard Templates" that might have what you are looking for
  • JuanCR
    0 JuanCR over 3 years ago
    Hi Sorin,
    This is currently a limitation of the tool. There is already an enhancement CCR in place for it.
