  3. How to add multiple heights to a component especially for...
  • State Verified Answer
  • Answers 1
  • Views 10974
How to add multiple heights to a component especially for connector models ?
Schulz Jordan
Schulz Jordan over 3 years ago
I have a connector model to which I need to add multiple heights, how can I do that In Allegro PCB editor ? I used package_heigt_min & package_height_max but that didn't help.
  • DavidJHutchins
    DavidJHutchins over 3 years ago +2 suggested
    When I worked at Intel we added multiple place_bound shapes for each specific height areas & then added the specific properties to each
  • jc teyssier
    jc teyssier over 3 years ago +1
    Placf bound are 3D cube; you can have as many place bound that needed in order to describe the component volume. Example: imagine a component touching pcb on left and right side but starting from 2mm…
  • excellon1
    excellon1 over 3 years ago +1 verified
    Hi Jordan. For component heights etc if a Step file is available then that can describe the package pretty good. If you have to create that package then that means using the placebound subclass. The…
  • DavidJHutchins
    0 DavidJHutchins over 3 years ago
    • Vote Up +2 Vote Down
  • jc teyssier
    0 jc teyssier over 3 years ago
    Example: imagine a component touching pcb on left and right side but starting from 2mm betxween thoses two side: both side will be drawn with individual  place bound with only the "max heigth" value and the intermediate part will be draw with a place bound having "min heigt" to 2mm and mmax heigth" same as the two others place bound.
    In fact you make a "cube" construction in order to describe the component volume.
  • excellon1
    +1 excellon1 over 3 years ago
    Hi Jordan.
    The easy way to do it is create the parts of your package bit by bit just using lines first. Then you compose those lines into a shape so as to make them solid.You apply package height max or package height minimum properties to show height in the Z-Plane of the package.
    here is a picture
    So to begin as an example and look at the circles in green. Draw your objects on the Package Geometry > Assembly top layer so as to describe the body of
    the package. When complete go to Shape > Compose a shape. In the options pane select package Geometry place bound top and draw a window box around each item. When complete you will have shapes to represent the flat lines. Right click on each shape to set the min, max height properties to give the shapes a Z-Height. Slide the shapes into place. Delete the original lines on the assytop layer if you don't need to keep them .
  • Schulz Jordan
    0 Schulz Jordan over 3 years ago in reply to excellon1
    Adding multiple place bounds helped
