  3. ODB++ Inside Backdrill Issue
  • State Suggested Answer
  • Answers 1
  • Views 10439
PCB6453
PCB6453 over 3 years ago
I have a board design that have backdrills.  Everytime, I would export out an ODB++ file, it gives me an error and would not let me proceed.  I was able to narrow the issue down to the backdrills.  Once I deleted the backdrill on the design as a test, the ODB++ Inside feature didn't have any issues.
Does ODB++ Inside support designs with backdrills?  If so, is there a special setting that I need to change?  If not, any ideas or recommendations on how to provide an ODB++ file to include the backdrills?
  • PCB6453
    PCB6453 over 3 years ago in reply to Schulz Jordan +1 suggested
    Schulz Jordan and oldmouldy I was able to track down the issue to the back drills. From there, I noticed that there was a negative value on the soldermask (padstack). Once I changed the value, all…
  • oldmouldy
    0 oldmouldy over 3 years ago
    This seems to be working fine with the 2211 ODB++ Inside. If you already have that, you should check that Artwork generation works without issue. If that also works, you would need to use the odbplusplus site and raise a support case for this.
  • PCB6453
    0 PCB6453 over 3 years ago in reply to oldmouldy
    Thank you oldmouldy.  The version of ODB++ Inside is indeed 2211.0001.  I will open a support ticket for this issue.
  • Schulz Jordan
    0 Schulz Jordan over 3 years ago in reply to PCB6453
    Can you share the error screenshot ?
  • PCB6453
    0 PCB6453 over 3 years ago in reply to Schulz Jordan
    I was able to track down the issue to the back drills.  From there, I noticed that there was a negative value on the soldermask (padstack).  Once I changed the value, all issues regards to exporting out ODB++ went away.
