  3. How to Set Different Net Clearances
  • State Suggested Answer
  • Answers 1
  • Views 10613
gazza47
gazza47 over 3 years ago
How Do you set up Net to Net Clearances for Cadence 17.4?
I have two nets PHA_OUT and PHA_MEASURE which requires a default clearance; however between PHA_OUT and PHA_MEASURE and all other nets on the board I require a larger clearance (400v).
How do I apply this in the Constraint Manager
Any assistance appreciated
Many Thanks
  • steve
    0 steve over 3 years ago
    You need to use the Net CLASS-CLASS rules. Go to YouTube and search for the parsyseda channel then look for Spacing Constraints and watch the video which covers this.
  • gazza47
    0 gazza47 over 3 years ago in reply to steve
    Thanks for your answer, I've had a look at your video and I'm not sure if this works the way my Constraints are set up.
    I have all my nets with a standard CSET of Default, I then have specific nets in a Class HV which I've set to CSET COATED_400V.
    What I require is the nets in Class HV to have a Default Clearance; however to all other nets they should have a clearance of COATED_400V
    I've not quite set things up correctly, can you advise how to  best set this up, when I select Class to Class the Default does not appear
  • steve
    0 steve over 3 years ago in reply to gazza47
    So you need to put all the nets in Netclasses, this can be individual (like Power, High Speed, etc) or just put all the remaining nets into one class called Default or Remainder. You can then create CLASS-CLASS rules for each. Default to HV would use the Coated Cset but Default to Default would just use your Default CSet.
  • gazza47
    All Sorted Thanks
