  3. Allegro – Tip of the week: Protecting alias/function ke...
  • Subscribers 163
  • Views 1579
Allegro – Tip of the week: Protecting alias/function keys
PCBTech
PCBTech over 3 years ago
Is there is a way to prevent users from creating aliases that are named the same as Cadence aliases, or the ones originated from site admins?
To protect (for example, read-only) alias/funckey assignments, use the alias_protect command.
The alias_protect command lets you assign an alias the “read-only” status, effectively disabling the ability to unalias/change a command.
To apply alias protection:
  • Type alias_protect at the tool’s user interface console command.
  • To apply protection to an aliased command, type -y and the alias name.
  • The defined alias will now be marked read-only and cannot be unaliased.
In this example, alias protection is applied to the F3 alias for add connect:
Command> alias_protect -y F3
Once this is protected, you get the following message while trying to assign F3 to some other command or unaliasing F3.
The F3 alias is marked read-only, not changed.
To remove alias protection:
  • To apply protection to an aliased command, type -n and the alias name.
    The defined alias can now be unaliased.
Command> alias_protect -n F3
Team PCBTech
Cadence Design Systems
