  3. Can't access file builder.ile
  • State Verified Answer
  • Views 1869
Kahraman
Kahraman over 3 years ago
I have been trying to create the files needed(.psm and .dra) for the pcb layout for this
DC/DC controller LM5117 by Texas Instruments. I downloaded the zip file from Ultralibrarian.
However when i run the .bat file which is in "AllegroV17_2" folder i get the following errors:
The files(.dra and .psm) are not generated after that.
The file "builder.ile" does exist in the above(in the pic) directory.
Do someone know how can i fix this?
Thanks!
  • Kahraman
    Kahraman over 3 years ago +1 verified
    FIX: The problem was with the path to the file(builder.ile). One of the folder was in cyrillic and the program could not read it.
  • Kahraman
    +1 Kahraman over 3 years ago
