  3. How to swap Pin in 1 component
  • State Verified Answer
  • Views 9464
YongLee96
YongLee96 over 3 years ago
I want to swap pin (change only x y position of pin, pin number and pin name remain unchanged) in the same component together.
This my code but it not work, can someone check where i made a mistake:
println("PLEASE SELECT 1ST PIN")
first_pin = car(axlGetSelSet())
first_xy = (car(axlGetSelSet())->xy)
axlClearSelSet()
println("PLEASE SELECT 2ND PIN")
second_pin = car(axlGetSelSet()
second_xy = (car(axlGetSelSet())->xy)
axlClearSelSet()
axlCompMovePin(first_pin , ?move second_xy)
axlCompMovePin(second_pin , ?move first_xy)
  • YongLee96
    YongLee96 over 3 years ago +1 verified
    I have realized the issue I encountered. The function "axlCompMovePin" is only available in Allegro® Package Designer. That is all I have been able to find out.
  • AsbjornEdvalds
    0 AsbjornEdvalds over 3 years ago
    The axlCompMovePin() function needs to get the delta xy, not the absolute xy. You can calculate the delta using axlMXYSub() function.
    That is, your two last lines would become
    axlCompMovePin(first_pin, ?move axlMXYSub(second_xy first_xy))
    axlCompMovePin(second_pin, ?move axlMXYSub(first_xy second_xy))
  • YongLee96
    0 YongLee96 over 3 years ago in reply to AsbjornEdvalds
    I fixed it according to your instructions and it still doesn't work.
    it does not return the value "t" or "nil"
  • YongLee96
    +1 YongLee96 over 3 years ago
  • Schulz Jordan
    0 Schulz Jordan over 3 years ago
    Did you try the method of pin grouping in schematics and updating same in PCB for pin swapping. This is the easiest way
