  3. IPC-356 Error
  • State Verified Answer
  • Subscribers 166
  • Views 9261
IPC-356 Error
Krutik
Krutik over 3 years ago
Error: Integer value 10800 cannot be written in columns 36-41 on line 106.
I got this error while generating the IPC-356 Netlist
Anyone Knows about how to fix this?
  • oldmouldy
    oldmouldy over 3 years ago +2 verified
    IPC-356 only allows -9999 to 9999 in the drill value. 9.999 inches would be a large drill but 9.999 mm is not that large. Modify the design Padstack to have a smaller drill to be able to the IPC-356 data…
  • oldmouldy
    +1 oldmouldy over 3 years ago
    IPC-356 only allows -9999 to 9999 in the drill value. 9.999 inches would be a large drill but 9.999 mm is not that large. Modify the design Padstack to have a smaller drill to be able to the IPC-356 data.
    • Vote Up +2 Vote Down
