  3. Null REGULAR-PAD specified when creating artwork
  • State Verified Answer
  • Views 12253
avant
avant over 3 years ago
On some designs, I get the warning "Null REGULAR-PAD specified for padstack SQ_P3XP3MM" and other padstacks.
What is odd is that the same footprint / pads used on another design does not give me the warnings.
I used the same artwork parameter files, and I replaced the footprint and padstacks.
I don't see any undefined or null shapes in the padstack.
Is there anything else I can look at to correct this?
  • steve
    steve over 3 years ago in reply to avant +1 verified
    Make sure that you are running the latest hotfix (17.4-2019 S036 or 22.1 S003) and see if that helps. If not. can you maybe upload a board (or a test board with this issue) so we can look a bit closer…
  • avant
    0 avant over 3 years ago in reply to steve
    Thanks Steve.
