  3. Null REGULAR-PAD specified when creating artwork
  • State Verified Answer
  • Views 12252
avant
avant over 3 years ago
On some designs, I get the warning "Null REGULAR-PAD specified for padstack SQ_P3XP3MM" and other padstacks.
What is odd is that the same footprint / pads used on another design does not give me the warnings.
I used the same artwork parameter files, and I replaced the footprint and padstacks.
I don't see any undefined or null shapes in the padstack.
Is there anything else I can look at to correct this?
  • steve
    steve over 3 years ago in reply to avant +1 verified
    Make sure that you are running the latest hotfix (17.4-2019 S036 or 22.1 S003) and see if that helps. If not. can you maybe upload a board (or a test board with this issue) so we can look a bit closer…
  • JuanCR
    0 JuanCR over 3 years ago
    try setting some copper in the pad and a non-plated hole
  • avant
    0 avant over 3 years ago in reply to JuanCR
    This is a surface-mount pad. I don't understand?
  • steve
    0 steve over 3 years ago in reply to avant
    Try a Database Check (Tools or Check menu) and see if that reports anything.
  • avant
    0 avant over 3 years ago in reply to steve
    Nothing reported after DB check.
    I get these null warnings on all of the pads in a design, but only certain designs. Some designs have no warnings.
    I can still create Gerbers, but it is irritating.
  • steve
    +1 steve over 3 years ago in reply to avant
    Make sure that you are running the latest hotfix (17.4-2019 S036 or 22.1 S003) and see if that helps. If not. can you maybe upload a board (or a test board with this issue) so we can look a bit closer. If not you may have to send it to Cadence support or Channel Partner to investigate.
