  3. Allegro PCB Router quit unexpectedly with an exit code of...
  • State Verified Answer
  • Views 10825
Allegro PCB Router quit unexpectedly with an exit code of 3.
OrCADbeginner
OrCADbeginner over 3 years ago
OrCAD PCB Designer Professional w/PSpice (17.2) で自動ルーターを実行すると、上記のエラー メッセージが表示され、拒否されます。フォルダ スペース、ログイン名、Via、Cline などを削除するなど、コミュニティであらゆることを試しましたが、何も解決しないようで、原因がわかりません。
  • OrCADbeginner
    OrCADbeginner over 3 years ago in reply to Andrew Beckett +1
    My apologies. The question is as you specified period. Is there any possible cause?
  • mahimag
    mahimag over 3 years ago in reply to OrCADbeginner +1 verified
    if spacing in design name and the directory path is not an issue, may be check the spectra.log if it gives any other error?
    0 Andrew Beckett over 3 years ago
    This went into moderation because of the use of Japanese characters. Please post questions in the forums in English (you're more likely to get an answer that way).
    Here's the question asked above:
    When I run the autorouter on , it rejects with the above error message. I've tried everything in the community, including deleting folder spaces, login names, Via, Cline, etc. but nothing seems to help and I don't know why.
  • OrCADbeginner
    0 OrCADbeginner over 3 years ago in reply to Andrew Beckett
  • OrCADbeginner
    I posted this in Japanese, so I am posting it again in English.
    I have taken all measures to address the information posted, including removing the folder space, login name, Via, Cline, etc., but I still get "Allegro PCB Router quit unexpectedly with an exit code of 3". error persists.
  • OrCADbeginner
    PS
    Route Editor is working fine and the auto router seems to be working.
  • mahimag
    +1 mahimag over 3 years ago in reply to OrCADbeginner
