  3. Site-defined Mask Layers not showing up in Add Layers menu...
  • State Verified Answer
  • Replies 8
  • Answers 1
  • Views 11712
Site-defined Mask Layers not showing up in Add Layers menu?
Netsballer92
Netsballer92 over 3 years ago
Site-defined Mask Layers not showing up in Add Layers menu? How can I add this? I want to add an Adhesive Top Layer.
  • steve
    steve over 3 years ago in reply to Netsballer92 +1 verified
    So as I first said you need to generate a masklayersitefile,xml, put it in a directory then point the materialpath to look at that location. Heres a COS solution How to create masklayersitefile.xml file…
  • Netsballer92
    0 Netsballer92 over 3 years ago in reply to steve
    Thank you very much.
  • Netsballer92
    I tried to open the link, but it brings me here.
  • steve
    0 steve over 3 years ago in reply to Netsballer92
    So you need the either the HOSTID that your software license is hosted on or Reference key (which is allocated by the Cadence Channel Partner if you bought through them). You need a valid maintenance contract to be able to access the Cadence support site.
