  3. Site-defined Mask Layers not showing up in Add Layers menu...
  • State Verified Answer
  • Replies 8
  • Answers 1
  • Views 11711
Site-defined Mask Layers not showing up in Add Layers menu?
Netsballer92
Netsballer92 over 3 years ago
Site-defined Mask Layers not showing up in Add Layers menu? How can I add this? I want to add an Adhesive Top Layer.
  • steve
    steve over 3 years ago in reply to Netsballer92 +1 verified
    So as I first said you need to generate a masklayersitefile,xml, put it in a directory then point the materialpath to look at that location. Heres a COS solution How to create masklayersitefile.xml file…
  • steve
    0 steve over 3 years ago
    Make sure that your materialpath (Setup - User Preferences - Paths - Config) is set to define where your site defined layers are configured. There should be a masklayersitefile.xml here that defines the layers.
  • Netsballer92
    0 Netsballer92 over 3 years ago in reply to steve
    Thank you for the response, I was not able to find it.
  • steve
    0 steve over 3 years ago in reply to Netsballer92
    Its in the screenshot you sent - third from the bottom..........
  • Netsballer92
    Ok, got it. What do I do now? Im not sure where my site defined layers are configured.
  • steve
    +1 steve over 3 years ago in reply to Netsballer92
    So as I first said you need to generate a masklayersitefile,xml, put it in a directory then point the materialpath to look at that location. Heres a COS solution How to create masklayersitefile.xml file (cadence.com)
