  3. Issue in creating Xnet in Allegro 17.2
  • State Verified Answer
  • Subscribers 166
  • Views 11541
RockNish
RockNish over 3 years ago
I am trying to create XNET in design but , it is not creating. I am following below steps:
* assign model from Analyze->Model Assignment->select discrete components and assign default model
I have two issues:
1. Auto setup is not showing
2. Xnet is not showing in Constraint Manager.
Kindly help out.
  • IMAN77
    0 IMAN77 over 3 years ago
    Please see the fix below
    techsupport.ema-eda.com/.../48001156940-xnets-not-being-created-in-constraint-manager
  • oldmouldy
    +1 oldmouldy over 3 years ago
    See this note on the Cadence Support site: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O0V000006D7zIUAS&pageName=ArticleContent The design may be in DML Independent mode and not using Signal Models to create XNets.
  • RockNish
    0 RockNish over 3 years ago in reply to IMAN77
    Thanks for reply,
    Yes resolved the issue.
    I have followed below steps:
    Tools->utilities->ENV Variable -> found envpath
    after going to above path and editing ENV file by adding text
    then restarted PCB Editor.
    Go to CM->Tools->Options-> changed tick to below option.
    Yes It worked well!
    Thanks Again IMAN77,
