  3. SPB17.4 Installation on RHEL 8
  • State Suggested Answer
  • Answers 1
  • Views 11021
toldav
toldav over 3 years ago
Hi Guys,
Does anyone have instructions to install spb17.4 on RHEL 8? or have experience any issues with any packages installation?
Thank you
David
  • JuanCR
    JuanCR over 3 years ago +1 suggested
    Hi David, According to the official compatibility list of 17.4, RHEL 8 is not a supported version of the OS. This is what the documentation states: Linux System Requirements This section describes…
  • JuanCR
    0 JuanCR over 3 years ago
    Hi David,
    This section describes the system requirements for Linux.
    Operating System
    RHEL 7.9 (64-bit); RHEL 7.4 (64-bit); RHEL 6.5 (64-bit); SLES 11 SP4 (64-bit); SLES 12 SP3 (64-bit)
    Supported Platforms for License Server
    Cadence® License Server 20.01, HotFix 002 is based on FLEXnet v11.17.1.0 supports the following platforms:
    Windows Linux Ubuntu
    Windows 10
    Windows Server 2012
    Windows Server 2016
    Windows Server 2019
    Linux RHEL6
    Linux RHEL7
    Linux SLES11
    Linux SLES12
    Ubuntu 14.04
    You can find more in this link:
    https://support.cadence.com/apex/techpubDocViewerPage?xmlName=pcbsystemreqs.xml&title=Allegro%20Platform%20System%20Requirements%20--%20Allegro%20Platform%20System%20Requirements%20-%20Linux%20System%20Requirements&hash=pgfId-1043568&c_version=17.4-2019&path=pcbsystemreqs/pcbsystemreqs17.4-2019/chap1.html#pgfId-1043568
    I've also found the list of packages that are installed for other versions of Allegro that do support RHEL 8. You can try installing these but since it's not officially supported in 17.4, there is no guarantee that it'll work. Please do get back to us with your results, specially if positive:
    Platform
    Requirement
    Patch Needed
    RHEL 8.4 (x86_64)
    Additional packages added:
    autofs-5.1.4-48.el8.x86_64
    net-tools-2.0-0.52.20160912git.el8.x86_64
    nfs-utils-2.3.3-41.el8.x86_64
    nss-pam-ldapd-0.9.9-3.el8.x86_64
    openldap-clients-2.4.46-16.el8.x86_64
    sendmail-cf-8.15.2-34.el8.noarch
    ftp-0.17-78.el8.x86_64
    ksh-20120801-254.el8.x86_64
    mailx-12.5-29.el8.x86_64
    mlocate-0.26-20.el8.x86_64
    tcsh-6.20.00-13.el8.x86_64
    perl-LDAP-0.66-7.el8.noarch
    perl-Convert-ASN1-0.27-17.el8.noarch
    tk-8.6.8-1.el8.x86_64
    libjpeg-turbo-utils-1.5.3-10.el8.x86_64
    xorg-x11-server-Xvfb-1.20.10-1.el8.x86_64
    ncurses-compat-libs-6.1-7.20180224.el8.x86_64
    libnsl-2.28-151.el8.x86_64
    libpng12-1.2.57-5.el8.x86_64
    redhat-lsb-core-4.1-47.el8.x86_64
    compat-openssl10-1.0.2o-3.el8.x86_64
    xterm-331-1.el8_3.2.x86_64
    perl-Env-1.04-395.el8.noarch
    xorg-x11-fonts-ISO8859-1-75dpi-7.5-19.el8.noarch
    expect-5.45.4-5.el8.x86_64
    ipmitool-1.8.18-17.el8.x86_64
    vim-X11-8.0.1763-15.el8.x86_64
    Patch Updates:
    nettle-3.4.1-4.el8_3.x86_64.rpm
    gnutls-3.6.14-8.el8_3.x86_64.rpm
    nettle-devel-3.4.1-4.el8_3.x86_64.rpm
    gnutls-devel-3.6.14-8.el8_3.x86_64.rpm
    gnutls-c++-3.6.14-8.el8_3.x86_64.rpm
    gnutls-dane-3.6.14-8.el8_3.x86_64.rpm
    java-1.8.0-openjdk-headless-1.8.0.292.b10-0.el8_3.x86_64.rpm
    java-1.8.0-openjdk-1.8.0.292.b10-0.el8_3.x86_64.rpm
    java-1.8.0-openjdk-devel-1.8.0.292.b10-0.el8_3.x86_64.rpm
    firefox-78.10.0-1.el8_3.x86_64.rpm
    bind-export-libs-9.11.26-4.el8_4.x86_64.rpm
    bind-libs-9.11.26-4.el8_4.x86_64.rpm
    bind-libs-lite-9.11.26-4.el8_4.x86_64.rpm
    bind-license-9.11.26-4.el8_4.noarch.rpm
    bind-utils-9.11.26-4.el8_4.x86_64.rpm
    python3-bind-9.11.26-4.el8_4.noarch.rpm
    Optional:
    tigervnc-1.11.0-6.el8.x86_64
    tigervnc-server-1.11.0-6.el8.x86_64
    Hope this helped.
  • toldav
    0 toldav over 3 years ago in reply to JuanCR
    Hi JuanCR
    Thank you for the valuable information.
    I wonder if that supports RHEL 8 since RHEL 8 is been around for a while.
    I will try to give it a try and get back to you.
    Thank you,
    David
  • toldav
    Hey JuanCR,
    It doesn't work!.  I'm hoping it will be compatible in 2024 as per their documentation.
    Thank you,
    toldav
