  3. selecting voids by radius or dimeter
  • Views 8046
masamasa
masamasa over 3 years ago
hello
is there a way to select a circle void by radius or diameter?
there is no radius or diameter option on find by query on voids.
i can only select voids by area but it picks up non circle voids.
regards
masa
  • JuanCR
    0 JuanCR over 3 years ago
    Unfortunately there is no option to do that as of now, but a workaround might be adding the COMMENT property to circular voids. For example, you can make this property value equal to "CIRCLE" and then use it as a filtering criteria in the Find by Query window
  • masamasa
    0 masamasa over 3 years ago in reply to JuanCR
    thank u for your comment. unfortunately adding the comment proprty to tens of thousand of voids is unrealistic. thank u for ur comment anyway.
