  3. Checking the status of the component placement inside the...
  • Replies 9
  • Views 12587
Checking the status of the component placement inside the board outline.
JITHINDEV
JITHINDEV over 3 years ago
Hi Guys,
Whether we can check the status of components placed inside the board outline?
Cheers
Jithindev
  • mcatramb91
    0 mcatramb91 over 3 years ago in reply to JITHINDEV
    Unfortunately, there is no way to report components which are only placed inside of the board outline, Design Status only reports components that are still in the placement list.  There is a DRC Check that will detect when a component is placed outside the Package Keepin but no summary report for components inside board outline - that would be a great addition to Design Status.
    How to display DRC Error when component is placed outside of Package Keepin:
    1. In Constraint Manager, select Analysis Mode from Analyze Menu
    2. Under Design Category, expand Package and enable Package to Package Keepin
    3. DRC marker will be placed along board outline aligned to component
      • Displayed on DRC ERROR CLASS / PACKAGE_TOP or PACKAGE BOTTOM
    Hope this helps,
    Mike Catrambone
  • JITHINDEV
    0 JITHINDEV over 3 years ago in reply to mcatramb91
    Hi  mcatramb91,
    The number of edge connectors will be get added when looking at the DRC errors.
    can we use the find by query method..? Like a number of components present in a specific area.
    for Eg: components present in the design outline.
    This is new to me. I need some help if you're able to.
    Cheers
    Jithindev
  • aniju
    0 aniju over 3 years ago
    if you need a count of specific area, Please follow below.
    Click on Show element,
    In Find Filter > All OFF > Check only Symbols, Drag the area which you looking for it will list out number of elements.
  • JITHINDEV
    0 JITHINDEV over 3 years ago in reply to aniju
    Hi Aniju,
    If we are doing like this Manually placed component count also get added here.
    Cheers,
    Jithindev
