  3. How do you remove soldermask from a Trace (RF Track) ?
  • State Suggested Answer
  • Replies 12
  • Answers 1
  • Subscribers 168
  • Views 15940
Jarez95
Jarez95 over 3 years ago
I have an RF track, how do I remove the soldermask above that specific track so that the RF performance is not affected. To be clear I dont want to remove the soldermask from the whole board and I hope this doesnt involve some kind of complex skill code solution. I am using SPB17.2-2016.
Many thanks in advance.
  • masamasa
    masamasa over 3 years ago +1
    the route keepout can be used if your soldermask is a shape.
  • steve
    steve over 3 years ago in reply to Jeff H +1
    No it simply copies the cline path to a route keepout area on a lyer defined by the user, increased by a defined amount.
  • Jarez95
    0 Jarez95 over 3 years ago in reply to steve
    Is there a tutorial on how to use it ?
  • Jarez95
    0 Jarez95 over 3 years ago in reply to avant
    I don't see a file export IPF, I see IPC, IDF and IDX in the export options only.
  • masamasa
    0 masamasa over 3 years ago in reply to Jarez95
    you can create a shape from clines of your traces.
    Defining path for critical signals | OrCAD PCB Designer - YouTube
    then you can copy the shape to the soldermask of your component.
  • steve
    0 steve over 3 years ago in reply to Jarez95
    Its should be self explanatory, invoke the command, select the track you want to add the keepout to and fill in the form (PDF attached). I would add that this only creates a routekeepout, you would then need to copy that to the soldermask_top or _bottom layer. ClineToRouteKeepout_help.pdf
  • Jeff H
    0 Jeff H over 3 years ago in reply to steve
    Steve, does it put a soldermask dam between the component pads and the trace?  Looking at the pictures, it doesn't look like it does.  Here is what I normally do to make the contract mfg happy.  If I remove the gap, they always complain
