  3. How do you remove soldermask from a Trace (RF Track) ?
  • State Suggested Answer
  • Replies 12
  • Answers 1
  • Subscribers 168
  • Views 15939
Jarez95
Jarez95 over 3 years ago
I have an RF track, how do I remove the soldermask above that specific track so that the RF performance is not affected. To be clear I dont want to remove the soldermask from the whole board and I hope this doesnt involve some kind of complex skill code solution. I am using SPB17.2-2016.
Many thanks in advance.
  • masamasa
    masamasa over 3 years ago +1
    the route keepout can be used if your soldermask is a shape.
  • steve
    steve over 3 years ago in reply to Jeff H +1
    No it simply copies the cline path to a route keepout area on a lyer defined by the user, increased by a defined amount.
  • masamasa
    0 masamasa over 3 years ago
  • Jarez95
    0 Jarez95 over 3 years ago in reply to masamasa
    I dont have the soldermask manually defined at the board level, the only soldermask layers I have are defined at the component level. Are you saying the only way is to draw soldermask shapes on top of the RF Tracks I have and then use the keepout rule ?
  • steve
    0 steve over 3 years ago
    There is a free app available from the EMA App store that will do this for you. Check out:- Download the GraserWare ClineRouteKeepout App - OrCAD Software Apps and Extensions | EMA Store (ema-eda.com)
  • avant
    0 avant over 3 years ago
    I would simply draw a line (on a solder mask layer) over the trace. Set the desired line width for the line/
  • avant
    If the RF trace has curves or is complex, copy the trace onto a blank area on the board file. Use file/export/IPF to create a plot file of the trace. This will create a line.
    Use file/import/IPF. Set the current layer to a solder mask layer. After importing, you can change the line width and move the (solder mask) line to be over the trace.
