  3. which autocad version is support cadence allegro 17.X version...
  • Replies 9
  • Views 12186
which autocad version is support cadence allegro 17.X version ?
kabalee
kabalee over 3 years ago
Hi Team,
i red the below link which help but can any one suggest which auto cad version will support allegro 17.x Version ??
community.cadence.com/.../dxf-file-layers-missing-when-attempting-to-import-into-pcb-editor
I got same issue which mention in above link can any suggest it .
  • masamasa
    masamasa over 3 years ago +1
    which autocad version do u have?
  • aniju
    aniju over 3 years ago +1
    allegro imports DXF which have version of 12 and more, if any unsupported feature will be ignored and reported in the log file.
  • masamasa
    masamasa over 3 years ago in reply to kabalee +1
    when u export ur data as dxf, it usually asks u which version of dxf format u need as shown below.
  • TCHA
    0 TCHA over 3 years ago in reply to kabalee
    When you import a .dxf file in Allegro, you also need to specify a layer conversion file (.cnv) to map classes and subclasses to specific DXF layers. Do you see any error/warning messages when trying to import the .dxf file?
  • TCHA
    @kabalee, are you seeing any error/warning messages when trying to import the .dxf file?
  • kabalee
    0 kabalee over 3 years ago in reply to TCHA
    there is no warning.. but i  can import same dxf in altium.. but it is not support in allegro
  • TCHA
    @kabalee, since debugging this issue requires data exchange, we will contact you through a different channel.
