  3. PCB Outline
  • State Verified Answer
  • Views 10708
PCB Outline
ivy372
ivy372 over 3 years ago
Hi guys,
I have write a skill that change origin to low-left of the PCB  board.
But how can I change the origin to the Board outline center point?
axlCmdRegister( "o_ll" 'o_ll ?cmdType "interactive")
(procedure o_ll()
axlExtentDB()
x = -( caar( axlExtentDB()))
y = -( cadar( axlExtentDB()))
axlDBChangeDesignOrigin( x:y )
axlUIConfirm( "Change Origin to LowLeft.")
Thanks~
  • DE202408202727
    DE202408202727 over 3 years ago +1
    Try something like this: outlineShp = car(axlDBGetShapes("BOARD GEOMETRY/DESIGN_OUTLINE")) || car(axlDBGetShapes("BOARD GEOMETRY/OUTLINE")) if(outlineShp then centrePt = axlMidPointLine(outlineShp -…
  • DE202408202727
    DE202408202727 over 3 years ago in reply to ivy372 +1 verified
    axlClearSelSet() axlSetFindFilter(?enabled '("noall", "invisible", "linesegs"), ?onButtons '("noall", "linesegs")) axlAddSelectAll() outlineSegments = setof(obj, axlGetSelSet(), obj ->layer == "BOARD GEOMETRY…
  • DE202408202727
    DE202408202727 over 3 years ago in reply to JITHINDEV +1
    Hi Jithindev, It's only a snippet of the code you need. To run it you will need to put it in a function. I suggest you read up on Skill. Alternatively you can run it line by line in a Skill window…
  • DE202408202727
    0 DE202408202727 over 3 years ago in reply to JITHINDEV
    Hi Jithindev,
    Alternatively you can run it line by line in a Skill window. Open a Skill window by typing "set telskill" on the command line. Copy and paste each line, one by one.
