  3. Toggle two recorded script file
  • State Suggested Answer
  • Answers 2
  • Views 8133
Netsballer92
Netsballer92 over 3 years ago
Is it possible to toggle two script files that I recorded? ex: funckey 0 "toggle replay 'TEST1'  'TEST2' "
  • mahimag
    mahimag over 3 years ago +4 suggested
    Hi, you can try below setup to toggle replay of your scripts: funckey x "replay x.scr" funckey y "replay y.scr" funckey a 'settoggle CMD x y;$CMD' If you write this in PCB Editor Command line, it…
  • Netsballer92
    Netsballer92 over 3 years ago in reply to mahimag +2 suggested
    Thank you, I also got this to work by: funckey x "settoggle layer_switch2 Test_ON_OFF Test2_ON_OFF Test3_ON_OFF; replay $layer_switch2"
  • mahimag
    0 mahimag over 3 years ago
    If you write this in PCB Editor Command line, it is valid only during the current PCB Editor session.
    You can enter the above commands in your local env file. The env file resides in your pcbenv folder in your HOME directory.
    • Vote Up +4 Vote Down
  • Netsballer92
    0 Netsballer92 over 3 years ago in reply to mahimag
    • Vote Up +2 Vote Down
