  3. Cross-probing issue in OrCAD 22.1
  • Replies 8
  • Subscribers 160
  • Views 10381
JITHINDEV
JITHINDEV over 2 years ago
Hi All.
Cross probing is not working from board file to schematics. but its working properly in schematics to board file. I'm using OrCAD 22.1-2022-S004
Can somebody guide me to fix this problem?
Cheers
Jithindev
  • VVRD
    0 VVRD over 2 years ago
    Hello Jithin,
    Try resetting allegro.ini file which is in your C:\Users\AppData\Roaming\SPB_Data\pcbenv folder (delete allegro.ini file, open and close any board file, new allegro.ini file should appear in pcb env folder). Make sure you have a copy of .ini file before you reset the original one.
    Thank you.
  • JITHINDEV
    0 JITHINDEV over 2 years ago in reply to VVRD
    Hi VVRD,
    I appreciate your response, and I followed what you suggested. still, the problem persists.
    Cheers
    Jithindev
  • VVRD
    0 VVRD over 2 years ago in reply to JITHINDEV
    Hii Jithin,Can you check allegro_no_xprobe is enabled?
  • JITHINDEV
    Hi VVRD,
    allegro_no_xprobe  is not enabled.
    Regards
    Jithindev
  • VVRD
    are you getting any error message when you're trying to cross probe from board to schematic?
