  3. PDF is not generated in 16.6 but it is generated in 17.2...
  • State Verified Answer
  • Subscribers 166
  • Views 8752
PDF is not generated in 16.6 but it is generated in 17.2 ?
kabalee
kabalee over 3 years ago
Hi Team,
i could not generate PDF in 16.6 but if open the same board file in 17.2 . I can generate PDF. Let me explain any one.. why it is happen.. I am using Cadence 16.6  and 17.2 in one system. is i need to purchase PDF generator separate for 16.6 ? so i will inform to IT Team related issue.
All the project done in 16.6 for one customer. so can any one help.. or need to add any hot fix ?
HOT FIX used S115.
  • Robert Finley
    0 Robert Finley over 3 years ago
    PDF export for schematics as a license option is usually a Concept HDL problem.  That is weird.
    If the problem is pdfs of schematics, I have Allegro/Orcad 16.6 to edit pcbs because MGC won't update their translator for 17.x.
    Export intelligent PDF is a Tcl routine in CIS..  I don't think it is license controlled.   Use a later version to generate the PDF?
    For the sch DSNs, I go back and forth constantly between 16.6, 17.4 and 22.1 and have not corrupted/upconverted an Orcad CIS DSN files.  Even crossprobing works.
    I build library symbols using CIS 16.6 but work in 22.1.   Major revs have separate Capture.ini files which gives me separate last-edited file histories.
  • steve
    +1 steve over 3 years ago
    The PDF generator was a paid for option @ 16.6. There was a free version introduced in 17.2 onwards (limited version of the pdf creator). Either open a copy of the board in the later version and generate the PDF or purchase a license.
